took the port side drain off, and noticed I didn't get a lot of water out on that side, so started examining closer and found a small piece of rubber in the block drain. I didn't lose an impeller this year, I think the end of last year it was starting to go, but I replaced it with a new one to start the year. If I have rubber all the way down at the bottom drain, do I need to start trying to back flush?
RE: winterizing and uh-oh found some rubber in one block dra
NO BIG DEAL!
I have over the years seen, rubber, large flakes of rust, mud even small sticks come out of my drains before CC went to a filter on the intake and I have never had any problems. I wouldnt worry, what ever happen it will just work it way through. A small peice of rubber will not block the normal cooling water flow.2012 Team Ski Nautique ZR409
2011 Sport Nautique 200
2008 SANT 230
2003 Air Nautique 226
1988 Martinique
1979 Nautique
1978 Tique
1976 Tique (First New Boat)
Grab the piece of robber with a pair of needle nose pliers. and pull it out. If you are feeling ambitious, disconnect the hoses at the thermostat top cover, and hook a garden hose there, with the drain plug out. Poke up into the exhaust manifold water jacket and you can get quite a lot of loose rust flakes to come out.
I would then restart the engine, after hooking the hoses back up, to be absolutely sure no water went where it is not suppose to.
Re: winterizing and uh-oh found some rubber in one block dra
Originally posted by Miljacktook the port side drain off, and noticed I didn't get a lot of water out on that side, so started examining closer and found a small piece of rubber in the block drain. I didn't lose an impeller this year, I think the end of last year it was starting to go, but I replaced it with a new one to start the year. If I have rubber all the way down at the bottom drain, do I need to start trying to back flush?
Originally posted by MiljackAirtool,
I'm showing the wife your post, and let her know that expert only comments populate PN! 8-)
I'll let you know how that goes...
AirTool
