ZR409 VS Excalibur 5.7
  • gride300
    • Apr 2008
    • 1356
    • mobile, al
    i disagree. you DO need to winterize closed loop or not if thats what your climate requires., especially if not gonna be used
    • j2nh
      • Dec 2003
      • 628
      • Spread Eagle Wisconsin
      Closed loop on the ZR does not need to be drained. This also includes the heater.
      Open (lake/river) portion DOES need to be drained. Without running out to the garage to check this includes the strainer, impeller, and exhaust manifolds. Nice thing on the ZR is the drain system that grabs fresh water from the low spots and runs them to a common hose next to the hull drain. Undo the nut on the end of the hose and it drains all the fresh water out (still have to do the strainer).
      2018 200 Team H6
      2009 196 Team ZR 409
      2005 196 Limited ZR 375
      2003 196 Limited Excalibur
      1999 196 Masters Edition
      1987 ProStar 190
      • robertsmcfarland
        • Oct 2004
        • 544
        • Hyco
        • 2014 g23 550
        winterize
        six years of single digit winters for days at a time with no problems just take it for a winter run and put back on the lift. also never have un hook the batteries and never had to replace either, starts first time everytime. It must be a nautique thing. Go for the ZR409 it's great for the piece of mind and no worry.
        2013 G23 super air
        2010 230 super air
        2009 220 super air
        2008 210 super air
        2005 210 super air
        2003 calabria pro air
        • GoBig
          • Apr 2008
          • 551
          • Santa Cruz, CA
          Originally posted by Nautiquehunter
          Thanks for all your posts I'm getting closer to my completed order
          and it comes down to this.
          1- titon tower and full throttle package or
          2-FCT1 tower and 6.0L engine
          The cost of the boat with ether options is about the same.
          I am leaning toward #2 I just keep thinking what would I change
          on my current boat if I could .
          The answer is bigger engine even though I don't need
          the extra HP most of the time I know I can always
          throttle down but once at full throttle that's it.
          I have until Jan 17th [Chicago Boat Show] to decide.
          Given the choice, I'd go with option #2 as well. I'm a huge fan of the FCT1...throw in a larger motor with closed cooling, yeah, that would be my pick. The closed cooling would sell it for me...
          2003 SANTE
