I was thinking of adding closed cooling on my Excalibur if it's possible. I like the idea of not having to worry about an impellar breaking. Does anyone know if it can be done? and if so how much would it cost?
Closed cooling on Excalibur?
'08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
Tow Vehicle--05 GMC 2500 Crew Cab Short Bed 6.6L Duramax/Allison with a few mods
-GO DAWGS!-Tags: None
RE: Closed cooling on Excalibur?
You'll still have an impeller to check. Raw water cools the heat exchanger for the closed cooling as well as the exhaust system.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
yep and cost around 1000k installed
HUMAN BUILT = HUMAN FIXED
switchbait.com
Re: Closed cooling on Excalibur?
Originally posted by kevfran99I was thinking of adding closed cooling on my Excalibur if it's possible. I like the idea of not having to worry about an impellar breaking.
Whoever told you about the closed cooling system not having a RWP and having to deal with impeller maintenence should be informed. I'd hate to have them run into a problem!! If they do have a newer boat with the closed cooling, at least it should go into "limp" mode if over heated.
