I can't find the engine drain plugs on my 2007 PCM 330. Where are they located. Any other drain plugs other than the engine and manifolds?
Tags: None
RE: Engine drain plugs
On the Excalibur there is 2 drains in the block, for a straight inboard, one is starboard side were the knock sensor is located, if removed it needs to be replaced to a specific torque spec (15 lb ft), the other is on the port side forward, if you have a heater this drain is probably where your heater HW supply is connected. There should also be a drain plug just off the engine circ pump, 2 large plugs on the back side of the exhaust manifolds, 1 on the trans cooler. If you have a heater you need to drain that as well. See page 60 in your owners manual - Out of Season Storage - 13.
