Will a Mobil 1 Filter hit the manifold?
  • AirTool
    • 4049
    • Katy, Texas
    I've noticed some of the oil filters that cross over from the Motorcraft FL-1A are about 1/4" inch longer. The Mobil 1 was about 3/8" longer by my guess.
    Has anyone had a problem getting a longer filter on/off a 5.7 330 due to the filter hitting the ex manifold?
    AirTool
  • TRDon
    • Oct 2007
    • 722
    • MN
    RE: Will a Mobil 1 Filter hit the manifold?
    dont the manifolds go up from the ports on your boat? They do on mine and I could have one as long as I want as long as it doesnt hit the clamshell. Not sure if that is what you mean though?
    • Quinner
      • 2246
      • Correct Crafts
      If it's 3/8" longer then the Motorcraft filter you should be able to get it on, coming off may require you to tilt it to clear the threads. Just put it in a plastic bag when removing to catch any oil that may spill.
      TRDon, guessing he has an Excalibur which has a remote filter mounted above the exh manifold, thread side up. Just enough space below the filter to remove it while keeping the filter straight up and down, with a standard size filter anyways.
      • Hollywood
        • Sep 2003
        • 1930
        • WIIL
        Why are you using a Mobil 1 filter?
        • Quinner
          • 2246
          • Correct Crafts
          HW,
          I was thinking about asking that same question? Motorcraft has always been my filter of choice.
          • TRBenj
            • 1681
            • NWCT
            Mobil1 makes an excellent filter. Overpriced, IMHO, but at least its not a Fram! Wix/Napa and the Motorcraft filters are also excellent and more reasonably priced.
            I believe that M1 will fit, though. Pretty sure my buddy ran one for a while on his Excal/196.
            1990 Ski Nautique
            NWCT
            • AirTool
              • 4049
              • Katy, Texas
              Re: RE: Will a Mobil 1 Filter hit the manifold?
              See Quinner's response:
              Yep, exactly.
              I knew there would be at least one that couldn't resist.
              HW,
              Quinner...you had willpower to start but then caved in with peer pressure.
              I picked Mobil 1 as an example because it seemed extra long and I knew it would get "attention".
              Thanks for the responses. I might try it just to see if I can make it work. I agree....getting it off will be harder than getting it on.
              AirTool
