What is the easiest way?
  • wildsv211
    • Aug 2008
    • 63
    • NorCal
    What is the easiest way to drain the block and manifolds on my 06 SV211 Excaliber engin? Any help is appriciated. Thanks
  • Nautique211
    • Dec 2004
    • 42
    RE: What is the easiest way?
    I'll beat NatiqueJeff to the punch, look at the PCM owner's manual. The manual does a pretty good job with picture illustrations, check it out.
    • Hollywood
      • Sep 2003
      • 1930
      • WIIL
      Remove the drain plugs???
      • CradGen2
        • Aug 2020
        • 1343
        • Horseheads NY
        Comedians above. I had a 211 and found it to be the hardest N I've had to winterize. Remembering back a couple years, make sure you get the water pump jacket all the way in the front of the motor. I was always scared I missed something on that boat I use to put ANTI-Freeze in the block just to be sure. And Yes you need to take that support out on the drivers side.
