Impeller Breakdown!
  • 1975CCMustang
    • Jun 2004
    • 11
    Impeller Breakdown!
    When the impeller breaks down where do all the blades go? I found a few clogging the line on the inlet side of the pump, but will they make it through the engine and water pump? :?:
  • Bobby
    • Jul 2004
    • 87
    • Norman, OK
    chances are they ended up in the transmission cooler line. that's what happened with mine just this last week.
    1996 Sport Nautique w/ EFI GT-40
    • lcap
      • Nov 2003
      • 192
      I still had pieces being blown out of the exhaust during winterization (November) after mine blew apart in April. Did not have any problems as a result.
      • nch20skier
        • Feb 2004
        • 167
        • North Carolina
        In an attempt to minimize this type of problem I sugguest you spend the $20 and 20 minutes each spring and replace the impellor. I do this as part of my spring readiness procedures and hit the water without worries. :cheers:
        88 Barefoot Nautique
        05 206 Team
        • 1975CCMustang
          • Jun 2004
          • 11
          I had just replaced the impeller as I do every year, and keep 2 spares in the boat, but the poor little jabsco pump after 30 years of faithful operation just decided to shut down on me. I have ordered a new sherwood pump from skidim (since they don't make the jabsco) and a new raw water pump also. I have never had any trouble till now. You can't prevent every breakdown. But for a 30 year old boat it sure runs good!
          • nch20skier
            • Feb 2004
            • 167
            • North Carolina
            Wow, sounds like we are on the same line with the yearly change outs. I have and '83 and its great to see the older horses still out there pulling strong and fast.
            05 206 Team
