I need help on fixing a probelm: My 206 has a factory trick tank that when the thru hull value is open, fills itself w/o any need for the pump? Is this normal or is there a fix? Also trying to determine the ID of the hose that is connected to the thru hull as I would like to install a "T" for easier winterizeing of the tank and pump?
RE: 2003 206 with factory trick tank
Do you have a helm control valve as well? On our 05' it is below the dash on the left side panel, has an "Open" & "Close" on it? I will say that even with the helm control shut some water may still come in.
I had the same issue with my 03 206. The main shut off valves for the thru hull fittings are under the engine box with no helm control valves. I added helm control valves to mine and it fixed the problem. I used the TH marine valves. They have a kit that has the valves with control cables and mounting plates. Install this and you will have control of your tanks again.
- Mar 2002
- 16454
- Lake Norman
- Mooresville, NC
That's a VERY common problem on the '03 boats. See this thread for tons of information on the issue.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
