i do not have a wrench that fits the starter housing. a 5/8 is the only thing that will go on it but it is loose and i dont want to round the bolt head. any suggestions. 79 bf nautique 454. also steering is locked up. boat has been sitting a while and i just got it. any suggestions would be appreciated. thanks
RE: starter bolt/ steering locked
Should be a 3/8 bolt with a 9/16 head. Already rounded? or wrong bolt maybe? Would guess cable first on your steering. If it is outside and cold, like everywhere else, could just be a bit frozen water in the packing.the WakeSlayer
1968 Correct Craft Mustang
Use 6 point wrench not a socket. I had the same problem on a 88 with a 351. It is a special flanged head bolt but I do not recall what size the head is. FYI the hex head is not the same size as a standard threaed bolt but it is an inch size not metric. I bought a set of 6 point wrenchs.
Take the steering cable clamp loose from the top of your rudder, if the steering wheel is free then its something locking up the rudder. If it still wont turn its likly you need a new cable.2012 Team Ski Nautique ZR409
2011 Sport Nautique 200
2008 SANT 230
2003 Air Nautique 226
1988 Martinique
1979 Nautique
1978 Tique
1976 Tique (First New Boat)
