100 Amp Alternator? 99 Air
  • jaybird
    • Oct 2008
    • 516
    • North Alabama Lake Weiss
    RE: Re: RE: 100 Amp Alternator? 99 Air
    Hey Chexi,
    Mikeski is right, an automotive alternator on a boat is not as big a deal as some make it out to be. Should you do it? No. Will it hurt the boat? No. It works exactly the same as a marine alternator, the only differance is that a marine is "ignition protected" it is manufacture in a manner that prevents or greatly reduces the chance of producing a spark that may result in the ignition of fumes. I would change it but you were only in danger if you had a gas leaks or build up of fumes. It will not burn up or cause you any probelms unless it was connected to old 50 amps wiring.
    2012 Team Ski Nautique ZR409
    2011 Sport Nautique 200
    2008 SANT 230
    2003 Air Nautique 226
    1988 Martinique
    1979 Nautique
    1978 Tique
    1976 Tique (First New Boat)
      • Mar 2025
      Anyone know what this hole is for? Is this a speaker hole? My interior just had vinyl over that hole with "Correct Craft" embroidered there. I was thinking about adding 1 or 2 speakers to the front area. Were there other 99 nautiques that came with a single speaker in the nose?
      • jaybird
        • Oct 2008
        • 516
        Hole
        I don,t know but my 226 has the same hole. If I had to guess I would say a wrench access to the lifting eye bolt/nut.
        2008 SANT 230
        1988 Martinique
        1979 Nautique
        1978 Tique
        • wake_fun
          • 1330
          • CA
          • 1995 Super Sport
          RE: Hole
          That's what I'd say also.
          Photo Album
          Ballast Install 1
          Ballast Install 2
          Amp Install
          PPass Install
          Alternator Install
          • JUST-IN-TIME
            • Sep 2007
            • 293
            • ON YOUR BOAT
            Originally posted by AirTool
            Originally posted by JUST-IN-TIME
            you need to hook an amp meter and find out
            Your kidding, right? Tell him the rest of the procedure.
            Well amp meter connected to outpost pole of alt
            then you need a load on the battery to induce amperage
            also never run an ammeter on a boat also, it is not ignition prodected
            HUMAN BUILT = HUMAN FIXED
            switchbait.com
            • Mikeski
              • 2908
              • San Francisco, CA
              #21
              Just-in-time,
              That will not tell you much about the alternator capacity, only what it is currently putting out, rarely are they even close.
              Permanent ammeter is fine on a boat. Not ignition protected? An ammeter is simply a very sensitive voltmeter that measures the voltage drop across a calibrated voltage shunt, no switching - no sparking, no source of ignition. Ammeters are used frequently on boats.
              In your test, are you using a clamp on?
              What is the basis of your electrical knowledge? I have seen you provide some very good advice but I find this suggestion to be peculiar.
              • JUST-IN-TIME
                • Sep 2007
                • 293
                • ON YOUR BOAT
                #22
                yes clamp on, or you can use a vom
                you need to put a load on the battery to make the alternator work
                yes you will not get 100 amps out of 100amp alt, but it will be more than 65 amps
                read USGC regs on electrical components and come back to me on this answer
                switchbait.com
                • Mikeski
                  • 2908
                  • San Francisco, CA
                  #23
                  Re: RE: Re: RE: 100 Amp Alternator? 99 Air
                  Just-in-time,
                  VOM to measure more than 65amps of current? No way (at least not without a shunt circuit involved), VOMs max out around 10-15 amps, you are going to be replacing an internal fuse on the meter.
                  Show me where you think it says not to use an ammeter in the USCG regs. You must be mis-interpreting something.
                  No problems with ammeters on boats, just google marine ammeter. If you understood the innerworkings of an ammeter you would realize the only difference between an ammeter and voltmeter is the range of voltage.
                  • JUST-IN-TIME
                    • Sep 2007
                    • 293
                    • ON YOUR BOAT
                    #24
                    RE: Re: RE: Re: RE: 100 Amp Alternator? 99 Air
                    183.405 General
                    most guys just put it in anywhere
                    the reason not to use them is because most will sell you an automotive one and call it a marine one
                    We learned that in ABYC electrical school, told us to stay away from installing them
                    Some VOM's will handle over 100 amps, FLUKE makes one
                    switchbait.com
                    • AirTool
                      • Sep 2007
                      • 4049
                      • Katy, Texas
                      #25
                      Re: RE: Re: RE: Re: RE: 100 Amp Alternator? 99 Air
                      183.405 General
                      I'm not seeing it:
                      http://ecfr.gpoaccess.gov/cgi/t/text...dno=33;cc=ecfr
                      • Mikeski
                        • 2908
                        • San Francisco, CA
                        #26
                        RE: Re: RE: Re: RE: Re: RE: 100 Amp Alternator? 99 Air
                        Show me a VOM that measures 100 amps (non-clamp on) Fluke or otherwise, doesn't exist. Simply speaking, the test leads and internal wiring required would be prohibitive to manufacture. The device you may be thinking of is a load bank?
                        § 183.405 General.
                        Each electrical component on a boat
                        to which this subpart applies must
                        meet the requirements of this subpart
                        unless the component is part of an outboard
                        engine or part of portable equipment.
                        I don't see it there either, fire that instructor.
                        Check section 111.30–27, an ammeter is REQUIRED whenever a generator is on board, next time you are on a houseboat you will see it.
                        The only difference between the gauge part of a Voltmeter or Ammeter is the range of voltage being measured, display and bi-directional range on the ammeter, it is still measuring voltage, just the millivolt gain or drop across the shunt instead of source voltage.
                        sorry for the detour this thread has taken, I guess we have too much pent up winter weather frustration, so we just beat up on each other instead of going skiing.
                        • AirTool
                          • Sep 2007
                          • 4049
                          • Katy, Texas
                          #27
                          Re: RE: Re: RE: Re: RE: Re: RE: 100 Amp Alternator? 99 Air
                          Originally posted by Mikeski
                          sorry for the detour this thread has taken, ....
                          I apologize too. I don't like most of just-in-time's post and I just couldn't resist on this one.
                          Again....please forgive me.
                            • Mar 2025
                            #28
                            RE: Re: RE: Re: RE: Re: RE: Re: RE: 100 Amp Alternator? 99 A
                            What is life without a little spice?
