Starter engaged when engine running
  • philb
    • Jan 2009
    • 125
    • Australia
    I have a 08, 220. Intermitantly the starter stays engaged after the engine has started. The dealer made some adjustments, but the problem has returned.
    Yes its still under warranty, but because it is intermitant, it never happens in the workshop.
    I assume it is mechanical rater than electrical.
    Any clues on where to look?
  • JUST-IN-TIME
    • Sep 2007
    • 293
    • ON YOUR BOAT
    RE: Starter engaged when engine running
    either sticking relay or keypad
    HUMAN BUILT = HUMAN FIXED
    switchbait.com
    • philb
      • Jan 2009
      • 125
      • Australia
      any idea where the relay is?
      • JUST-IN-TIME
        • Sep 2007
        • 293
        • ON YOUR BOAT
        download the manual from here
        i want to say on starboard side
        it is a black square
        switchbait.com
        • AirTool
          • Sep 2007
          • 4049
          • Katy, Texas
          The starter bendix might be sticky. That is an easy fix after the starter is off. If the bendix sticks, the on-starter solenoid stays energized and the starter keeps cranking.
          I the old days, GM starters had to be shimmed properly. Not sure about now. I had this problem on a 72 firebird and ultimately the starter housing cracked.
          • JUST-IN-TIME
            • Sep 2007
            • 293
            • ON YOUR BOAT
            lets c an 08?
            check the relay with that ozy salt!
            switchbait.com
            • philb
              • Jan 2009
              • 125
              • Australia
              hasnt been is salt & only done 44hrs........
              Shimming wont help as the starter bolts up from the bottom.
              I feel it is electrical????
              The dealer is stumped also.
              We'll play around with few things this weekend & see where we end up.
              I'll let you know.......
              • AirTool
                • Sep 2007
                • 4049
                • Katy, Texas
                Starters that are shimmable (sp?) usually bolt up from the bottom. Which engine do you have? 5.7 or 6.0?
                With some electrical jumpers and such, this should be easy to troubleshoot. Isolate the gateway etc. while doing so so you don't back feed those.
                • philb
                  • Jan 2009
                  • 125
                  • Australia
                  6ltr 409HP
