I have a 03' SANTE and sometimes when I turn the heater on it kills all power and in some cases, if I'm going slow enough, kills the engine. Anybody eles have this problem?
Sounds like your alternator is bad or to small. Is there anything else on when this happens, ie radio lights etc. If so you are drawing to much power. Also the battery may have a bad cell Take it to Autozone have them charge it and then check it. Good luckNautiqueless in San Diego
Has this just started happening, or has it always happened when you use the heater? I would look toward the battery if it has just started happening. If it has always happened, I'd consider either replacing your current battery with a deep-cycle marine battery (if you don't already have one), or adding an additional battery. A high-output alternator might also help this problem.
Correct Craft does not put deep-cycle batteries in their boats from the factory (at least mine didn't have one), and I think they should.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
