Synthetic oil gt40
  • nautiquedave
    • Nov 2008
    • 10
    • Clearlake,California
    Synthetic oil gt40
    Am looking into using amsoil.What are the pros and cons Thanks
  • bchesley
    • Feb 2006
    • 1252
    • Tyler, Texas
    RE: Synthetic oil gt40
    Your thread title is synthetic oil gt-40, but your content is asking about Amsoil. I can't comment on the Amsoil but if you search for Royal Purple I have a thread with a response from the manufacturer on using it in a GT motor. I am planning to make the switch to Royal Purple because its the easiest to get for me. My local parts store keeps several cases of each W on hand. I have been running it in my Dodge Diesel for around 100k and really like it.
    2001 Super Air Nautique
    Python Powered
    100 Amp Alternator
    Dual Batteries
    Many upgrades coming...
      PCM recommends conventional oil.
      I recommend Valvoline VR-1 40W, and a Motorcraft FL-1A oil filter.
      My GT-40 has 1975 hours on it with this combination.
      Another 1998 Ski Nautique, with a GT-40, I take care of has 1367 hours on it.
      • DavidF
        • Sep 2004
        • 611
        • Austin, TX
        The GT-40 engine uses flat tappets. Conventional wisdom suggests that oil with zinc additive (ZDDP) be used on engines with flat tappets. Synthetics do not have zinc additive and most conventional oils do not. Valvoline VR-1 does and is what I use. The zinc additive prevents the oil from being sheared (squashed) out from between high load parts such as flat tappets.
        • bchesley
          • Feb 2006
          • 1252
          • Tyler, Texas
          DavidF,
          Read my thread on the Zinc levels of Royal Purple. I was using valvoline VR-1 until I found out that Royal Purple has the same zinc and some weights have higher Zinc levels. I have switched to RP. I am going to use their 30W in my V-drive too. I have already been using their ATF in my tranny for two seasons.
          Python Powered
          100 Amp Alternator
          Dual Batteries
          • WakeSlayer
            • Sep 2005
            • 2069
            • Silver Creek, MN
            • 1968 Mustang
            I have been running Mobil 1 15w50, in my 502 Chevy since I got it. It was suggested to me recently to switch back to a single weight conventional oil. Last year I finally installed a remote kit which uses the Ford filter FL1A. Any suggestions on converting back? And why would I do so. I am not a motorhead by any stretch so lay terms would be more helpful. I get all bleary eyed trying to read the multitude of oil threads that have been posted here in the past.
            the WakeSlayer
            1968 Correct Craft Mustang
            • TRBenj
              • May 2005
              • 1681
              • NWCT
              Re: RE: Synthetic oil gt40
              David, Im not sure that is true. I have seen a few datasheets for synthetics and certain ones (like RP or M1 15w50) have levels of zinc that are comparable to the VR1, etc. Agreed that you have to be very careful when selecting an oil with a FT cam, though.
              Originally posted by bchesley
              I have switched to RP. I have already been using their ATF in my tranny for two seasons.
              Be very careful what type of transmission fluid you use. I know that PCM does not recommend synthetics in the transmission, at least for the direct drives.
              Mike, that M1 youre using might be fine. If you can find the datasheet to confirm the zinc/phosphorus levels, that might give you some peace of mind. I want to say that your 502 is a FT engine- though Im nowhere near 100% certain about that. If it is and the ZDDP content of the M1 youre using is in the 1200-1400ppm range, you should be fine.
              1990 Ski Nautique
              NWCT
              • scoke
                • Jan 2008
                • 111
                • Baton Rouge
                RE: Re: RE: Synthetic oil gt40
                Some great info in this thread.
                I used the VR-1 in my boat but Shell Rotella T 15w40 was my other option but nobody carried it at the time.
                The Royal Purple has more zinc but the cost is quite a bit higher. For one oil change a season, it might be fine but if you are going to change your oil, 5-7 times a year, the cost adds up quick.
                • bchesley
                  • Feb 2006
                  • 1252
                  • Tyler, Texas
                  RP is definately more expensive but yes its only a change or two a year for me. I have shared boat time with three friends. We probably ride 200 hours a year, but only about 50 on mine and spread out on the others. I usually have 25-30 hours with the wife and kids so I am not racking up major hours.
                  Python Powered
                  100 Amp Alternator
                  Dual Batteries
                  • bchesley
                    • Feb 2006
                    • 1252
                    • Tyler, Texas
                    TRBenj,
                    You are correct, PCM used to say no to synthetics, but suddenly that is all you are supposed to use in their new tranny. Must have had a change of heart.
                    Brad
                    Python Powered
                    100 Amp Alternator
                    Dual Batteries
                    • WakeSlayer
                      • Sep 2005
                      • 2069
                      • Silver Creek, MN
                      • 1968 Mustang
                      I checked Mobil 1's data sheet, and it shows 1200ppm.
                      the WakeSlayer
                      • TRBenj
                        • May 2005
                        • 1681
                        • NWCT
                        TRBenj,
                        Brad
                        Not likely that it was a change of heart- Im sure there was a component change driving the recommendation in the V-drives. I can say with a lot of confidence that the older trannies (both PCM 1.23, 1:1 and BW 1:1) should not run synthetic.
                        1990 Ski Nautique
                        NWCT
                        • JUST-IN-TIME
                          • Sep 2007
                          • 293
                          • ON YOUR BOAT
                          Only thing on asmoil is the corrosion inhibitors are skimped on
                          i noticed this on lower unit fluid more
                          HUMAN BUILT = HUMAN FIXED
                          switchbait.com
                          • bchesley
                            • Feb 2006
                            • 1252
                            • Tyler, Texas
                            I have had good luck so far. I ran it in my old borg warner for a couple of summers too with no ill effects. I will be the test mule and see how far it will go.
                            Python Powered
                            100 Amp Alternator
                            Dual Batteries
                            • TRBenj
                              • May 2005
                              • 1681
                              • NWCT
                              Re: RE: Re: RE: Synthetic oil gt40
                              According to PCM, you wont see a failure right away but it does decrease the tranny's life. From what I remember from my conversation with them, they were seeing failures in the 600-800 hour range when running synthetic. Its just too slippery. Over 1200 hrs on my '90 1.23 that ran 20w most of its life. I disassembled it to change to ATF 2 years ago and it still looked great... I will be sticking with conventional Dex/Merc per the recommendation of the manufacturer and other tranny experts.
                              1990 Ski Nautique
                              NWCT
