First would like to thank everyone for there response on my other posts they are very helpful.My question now is where is the correct location for the shower/heater pump mine was zip tied to the exhaust right next to the alternator.I figured that was not right since the exhaust was collapsing from the zip ties.Any suggestions will help.Final question what is the correct impeller for a 99 nautique with a gt40 thanks.
Tags: None
RE: shower/heater pump location 99 v-drive
The heater does not use a seperator pump. The engine circulation pump takes care of it. The shower pump on my '99 NSS is bolted to the engine cradle on the starboard side about mid point. Not sure about impellar, I just pick them up at the dealer every few years. Sherwood standard stuff.
My pump is located in the back port side against the transom. I would double check your exhaust hose if it is collapsing from a zip tie. I do not think it should do that.
FWIW, I am removing my shower this Spring. I never use it.the WakeSlayer
1968 Correct Craft Mustang
Re: RE: shower/heater pump location 99 v-drive
Originally posted by WakeSlayerMy pump is located in the back port side against the transom. I would double check your exhaust hose if it is collapsing from a zip tie. I do not think it should do that.
RE: Re: RE: shower/heater pump location 99 v-drive
It is pre-sold, sorry.
Depending on the year, I think there is a connector tied up back by your motor. Cannot remember the color of wires.the WakeSlayer
For the shower pump, if they do them all the same, look behind the driverside rear motor mount. The last two I installed was there, zip tied to the bilge wires. Off the top of my head I believe it is a black wire for the ground and an orange wire witha black stripe. there will be a plug, on one side the wires go to the dash and on the other side it will be looped back to the plug.
