new 06 210 ballast pump help stopped working
  • wake4life6
    • Mar 2009
    • 218
    • Olympia, Washington
    just got a 210 with 35 hours took it out filled the tanks no problem went to pump out the water two pumps worked but the starboard wont turn on. don't think it hit the breaker no sound at all what could it be please help, thanks
    2006 210 SAN! TE
  • jward
    • Feb 2008
    • 620
    • Sweet Home Alabama
    • 03 SANTE 04 SANTE
    RE: new 06 210 ballast pump help stopped working
    when you hold the button down do you see the light blinking? Make sure the breaker isn't popped out. If the light is blinking you may just need to check the plug on the wiring by the pump.
    • ZANDERSANTE
      • Apr 2007
      • 120
      • Fishers, IN (Geist Reservoir)
      Check to make sure the pumps have had the updated impellers installed.. Got my 06 afew years back with 5 hours and the center tank wouldn't work. Impellers were sticking. Never had a problem since.
      06\' SANTE 210
      • wake4life6
        • Mar 2009
        • 218
        I just checked it the lights works pushed the breaker again wasn't popped but it just made the smallest hiccup noise but no real motor sound. don't know about the impeller did it cause your motor to make no noise?
        2006 210 SAN! TE
        • ZANDERSANTE
          • Apr 2007
          • 120
          Nope. All quiet.. Lights were on but nobody home.
          06\' SANTE 210
          • ZANDERSANTE
            • Apr 2007
            • 120
            Sounds like that's your problem. Check with your local dealer and have them run the VIN to see if the updates been done. Even if it isn't your problem, you should get them changed out anyways.
            06\' SANTE 210
            • WakeSlayer
              • Sep 2005
              • 2069
              • Silver Creek, MN
              • 1968 Mustang
              You can open the pumps up. IIRC black needs replacing, yellow = replaced. The old impellers would come apart in the housing. Easy fix.
              the WakeSlayer
              1968 Correct Craft Mustang
              • AuMDLST
                • Apr 2007
                • 870
                • Orlando, FL (Butler Chain)
                I have an 06 and you are most likely dealing with, as previously posted, the impellers. Typically when you reset the breaker they would work again for a period of time. Ensure you do not have the pump "on" when you reset the breaker, after reset then try again. I would imagine it will run for you, just a pain to reset them, until you can get it to a dealer for the service.
                2006 SANTE 210 (Pending Sale)
                2005 206 TE (Previous)
                • bchesley
                  • Feb 2006
                  • 1252
                  • Tyler, Texas
                  They have even newer ones now that are green. The yellows are failing too. The yellows are softer to keep from shredding too easily, but the centers are spinning loose after sitting up for winter. You dealer will have the new green ones. Mine does.
                  2001 Super Air Nautique
                  Python Powered
                  100 Amp Alternator
                  Dual Batteries
                  Many upgrades coming...
                  • WakeSlayer
                    • Sep 2005
                    • 2069
                    • Silver Creek, MN
                    • 1968 Mustang
                    Is Jabsco warranteeing (is that a word) the yellows and replacing them now? I know they were from black to yellow.
                    the WakeSlayer
                    • bchesley
                      • Feb 2006
                      • 1252
                      • Tyler, Texas
                      I am pretty sure the dealer will if you have a new boat with warranty, but not purchasers of pumps by themselves.
                      Python Powered
                      100 Amp Alternator
                      Dual Batteries
                      • WakeSlayer
                        • Sep 2005
                        • 2069
                        • Silver Creek, MN
                        • 1968 Mustang
                        Curious, cause they did before.
                        the WakeSlayer
                        • wake4life6
                          • Mar 2009
                          • 218
                          thanks for all the replies. Tried the breaker when off still nothing. Gonna take it in for warranty but is there a way to empty it so I don't have to haul it with it full?
                          2006 210 SAN! TE
                          • jward
                            • Feb 2008
                            • 620
                            • 03 SANTE 04 SANTE
                            remove the sending unit and stick a hose down in the hole and syphon it out. Had to do that before on my last boat.
