just got a 210 with 35 hours took it out filled the tanks no problem went to pump out the water two pumps worked but the starboard wont turn on. don't think it hit the breaker no sound at all what could it be please help, thanks
RE: new 06 210 ballast pump help stopped working
when you hold the button down do you see the light blinking? Make sure the breaker isn't popped out. If the light is blinking you may just need to check the plug on the wiring by the pump.
I have an 06 and you are most likely dealing with, as previously posted, the impellers. Typically when you reset the breaker they would work again for a period of time. Ensure you do not have the pump "on" when you reset the breaker, after reset then try again. I would imagine it will run for you, just a pain to reset them, until you can get it to a dealer for the service.2006 SANTE 210 (Pending Sale)
2005 206 TE (Previous)
They have even newer ones now that are green. The yellows are failing too. The yellows are softer to keep from shredding too easily, but the centers are spinning loose after sitting up for winter. You dealer will have the new green ones. Mine does.2001 Super Air Nautique
Python Powered
100 Amp Alternator
Dual Batteries
Many upgrades coming...
