343 Excalibur Oil Change?
  • SuperSquirt
    • Apr 2008
    • 534
    • Tennessee
    • 2008 SANTE 210
    I am trying to change the oil in my 210 with the 343 excalibur motor, and I can't get the oil to drain! I ran the motor for 25 minutes to warm up the oil, and then fed the drain tube through the bottom of the boat and nothing. I then tried sucking it out with a drill pump and then a Pela pump, and only got around 2.5 quarts or so out.
    What is the trick to get the darn oil out? I opened everything up to let it breathe better, but I'm starting to get pissed. I've changed the oil in my old inboard and all my cars for years, and this is my first try with the 343.
    Any tips?
    Also, how much pressure should I have at engine idle?
    How many quarts will it hold?
  • AirTool
    • 4049
    • Katy, Texas
    RE: 343 Excalibur Oil Change?
    25 minutes at idle might not warm your oil. Did you load it up for 25 or at idle with hose water?
    Make sure your hose is down on the bilge. On my 206, you have to carefully fish the hose so that there is not a hump that would prevent the oil to drain.
    I've changed mine hot and about 4 qts will come out in an hour or so. I prefer to let it drain overnight into an empty container with graduations like a 5g oil container I buy my truck oil in. Provided I was happy with the level before the change. I put back whatever drained out plus prime the oil filter. Usually I get 4.25 or so out of the pan. I've NEVER been able to put a full 5qts in after an oil change.
    It is possible that your hose is plugged up ....but probably not.
    There are several posts on oil changes and slow draining oil. Here is one:
    http://www.planetnautique.com/index....amp;highlight=
    • GoBig
      • Apr 2008
      • 551
      • Santa Cruz, CA
      I use the Moeller extractor on my EX343. Great product. It is a bit of a trick to get the hose all the way to the bottom of the drain pan. But once you figure out that last little twist, you should get a little over 4 quarts out. The Moeller extractor is awesome. You pump it about 5 times, it creates a vacuum and does the rest. Takes about 10-15 minutes for it to pull everything out. I cap it off, take it to Kragen and dump it in their recycler. Couldn't be any easier. Also, another note, I only run my boat for about 10 minutes before I start the drain. The Moeller is that good. Here is a link but search around a bit. You could probably get a better deal somewhere...
      http://www.boatersoutlet.com/moelleroilextractor.aspx
      2003 SANTE
      • SuperSquirt
        • Apr 2008
        • 534
        • Tennessee
        • 2008 SANTE 210
        I was fortunate enough to go out on the lake today and cruise around for a few hours. I had put 4 quarts of oil in after draining it yesterday, and it seemed to be fine today. I had oil pressure near 70 at high speed and 40 at idle, but my dipstick showed that I needed to add some more? Doesn't make sense, but I'm going to quit worrying about it now. Thanks for the help.
        • AirTool
          • 4049
          • Katy, Texas
          Re: RE: 343 Excalibur Oil Change?
          70 ! ? what kind of oil are you using?
          • SuperSquirt
            • Apr 2008
            • 534
            • Tennessee
            • 2008 SANTE 210
            RE: Re: RE: 343 Excalibur Oil Change?
            Shell Rotella 15W-40, do you think that is too high of pressure?
            • AirTool
              • 4049
              • Katy, Texas
              That does sound too high....but I can't say I've paid attention to my cold pressure. Maybe I'll see it in the next week or so and report back.
              • contour
                • Oct 2004
                • 20
                I've been using a small centrifical air pump, (like the type you would use to fill an air mattress) to push the oil out of the engine. I insert the end into the rubber hose that I remove from the air cleaner to the tappet cover. By doing this, it slightly pressurizes the inside of the engine, forcing the oil out the long restrictive hose
                • Kevin_B
                  • Jan 2008
                  • 313
                  • Greensboro, NC
                  • 2008 SANTE 220 1990 Sport Nautique
                  I just a bought a 220 with the EX343 and I can’t seem to fish the hose to the drain plug hole. This is how I always drained my Sport, am I approaching this wrong?
                  I don’t see how it could be done any other way. Any pointers on the entire process would be greatly appreciated.
                  1990 Sport Nautique
                  • Infinity
                    • Sep 2017
                    • 730
                    • Lake Norman - Denver, NC
                    • 2014 SV244 w/ ZR409
                    Use an extractor pump hooked to oil drain hose and pump it out. Takes about 10mins to remove the oil that way.
                    I use the small hose on extractor, put it inside the oil drain hose and push it up inside. With warm oil (run boat 10-15mins), it comes out easily and does not take long (do NOT recommend putting the hose inside the dipstick tube, several people have gotten the oil hose stuck in the engine doing it that way).
                    This is the oil extractor I use:
                    https://www.harborfreight.com/23-gal...tor-62643.html
                    • Infinity
                      • Sep 2017
                      • 730
                      Congrats on the new boat!
                      • azeus17
                        • Feb 2008
                        • 387
                        • Grand Rapids, MI
                        • 2022 GS22 - Coming in July Previous Boats: 1989 Sport Nautique 2002 SANTE
                        I do the same as above. I wish I would have discovered the extractor earlier! Just warm it up a bit, stick the extractor hose down the engine drain hose and pump it up. No mess and you don't have to stand on your head trying to fish the drain hose through the hull.
                        • ZachD
                          • Mar 2014
                          • 109
                          • Columbus OH
                          • 2014 G21
                          Same as above. Extractors are great. The drain hose is not pressurized so thumb tightening it works and clipping it one of the black hoses afterwards does the trick. Makes it easily accessible for next time.
                          • Beach-TJ
                            • Oct 2010
                            • 207
                            • Lake Lanier, Ga
                            • 2004 SAN 210 TE
                            Make sure the boat is level. When my boat is on the trailer and sitting on level ground I need to place a 4x4 under the Jack and max the Jack out to get the boat level ( same as sitting in water ).
                            Once level the oil will drain in about an hr. though I usually let it drain over night.
                            Always check your oil level with the boat free floating, no ballast, including no people, besides yourself.
