cutting bimini pole too
  • AirTool
    • Sep 2007
    • 4049
    • Katy, Texas
    The only rivets on my towerbimini are two rivets put in on each side to index the position the slide jaws. They don't fasten anything.
    It probably depends on the brand.
    • gride300
      • Apr 2008
      • 1356
      • mobile, al
      i had it fixed at my dealer and apparently they didnt measure twice cut once or put the bimini back on. b/c the pole they fixed is too long. i can't even figure out how to get the thing out. it's the piece of the bimini that is just a pole with a plastic cap with a hole in it on each end used for attaching to the tower. i have a cutting tool. but i can't get the cap off to cut the pole down.
      • AuMDLST
        • Apr 2007
        • 870
        • Orlando, FL (Butler Chain)
        Bimini end cap
        The end you are trying to remove - does it look similar to this? A cap over the end of the pole with two possibly silver in color rivets? The pic shows a cap with a set screw which yours is possibly similar in style but without a set screw. If you have rivets you should see a round head possibly a 1/4" in diameter with a small center hole that appears to be plugged. If that is the case you would get a drill bit that is just slightly larger than the center hole and drill it/them out - at that point you can twist the cap off.
        2006 SANTE 210 (Pending Sale)
        2005 206 TE (Previous)
        • saceone
          • 650
          • Montréal
          RE: Bimini end cap
          every man needs a saws all.
          • gride300
            • Apr 2008
            • 1356
            • mobile, al
            RE: Bimini end cap
            yes it looks just like that except the "fastener" is pushed in i guess you'd say like a dimple. i'll try drilling it out. saws all would not work in this application for removing the cap b/c the metal would still be in there. but yes, dewalt saws all ftw
            • AirTool
              • Sep 2007
              • 4049
              • Katy, Texas
              #21
              Re: RE: Bimini end cap
              I think someone already mentioned the dimple.
              • gride300
                • Apr 2008
                • 1356
                • mobile, al
                #22
                RE: Re: RE: Bimini end cap
                yes they did, that's how i knew to use that word. i appreciate the help. i can't get to the bimini until probably sunday.
