What transmission oil for '97 (DD) with PCM 1.23:1 trans?
  • AirTool
    • 4049
    • Katy, Texas
    I do the same as DanielC immediatly after launching and again after a workout. The temp and level rise some after a workout. I'd say if your water temps don't vary much and your level at any time is between 20% and 80% of the range...be happy and leave it alone. If you are close to either line, I'd watch it more carefully and then either add a little or take some out ...whatever the case is.
    There is one lake we visit that can get a little over 100F at the surface. That is probably my worst case adn 20F over my typical temp. That would cause a decent volume growth.
    I also don't check my fluid every outing.
    • mf01
      • Jun 2005
      • 515
      • Austin, TX
      Not sure if you're familiar with the Austin area, but I'm typically on Lake Austin. In the dead heat of summer it will only get to 75F.
      Previous:
      2011 Super Air Nautique 210
      1994 Sport Nautique
      • AirTool
        • 4049
        • Katy, Texas
        I'm a UT grad BSME 91.
        What gets to 75F? Lake Austin? ...or your tranny fluid?
        The top secret heated lake to your east gets over 100 F during late August to early September.
