RE: Re: RE: 4 awg crimper/stripper
Solder pellets work well too for large 4 gauge and larger wire. You can find the pellets online or at your local welding supply. Basically, you get the wire stripped and ready. Put the ring lug in a vise and drop the pellet in and heat with a torch. The pellet will liquify and then you just stick the wire in and hold. It makes a strong connection. I follow this up with a light crimp and then heat shrink with adhesive liner.
The electrical engineers at my friends plant do it this way and it is a strong seal. I can put the lug in my vise grip and pull the wire and can't seperate the connection.
