changing impellers on my 2006 ballast
  • wake4life6
    • Mar 2009
    • 218
    • Olympia, Washington
    Where can I buy these. And any info on doing this i suck at working on stuff any advice or forum links would be appreciative
    2006 210 SAN! TE
  • bchesley
    • Feb 2006
    • 1252
    • Tyler, Texas
    RE: changing impellers on my 2006 ballast
    www.whitelake.com you get a discount!
    2001 Super Air Nautique
    Python Powered
    100 Amp Alternator
    Dual Batteries
    Many upgrades coming...
    • WakeSlayer
      • Sep 2005
      • 2069
      • Silver Creek, MN
      • 1968 Mustang
      I think it just three screws on the cover. Extremely easy. Philips screw driver.
      the WakeSlayer
      1968 Correct Craft Mustang
      • wake4life6
        • Mar 2009
        • 218
        I checked whitelake didn't find impellers for the ballast . Where are they located. whats the best way to get to the pumps when i go to work on it . 06 210
        2006 210 SAN! TE
        • wake4life6
          • Mar 2009
          • 218
          found them took the pump apart impellers are good no power I hate this why wont it just work
          2006 210 SAN! TE
          • bchesley
            • Feb 2006
            • 1252
            • Tyler, Texas
            Check your breakers by your panel. They are prone to pop if your impellers are stuck over winter. You should be able to push them in an go now that you have freed up the impellers.
            Python Powered
            100 Amp Alternator
            Dual Batteries
            • WakeSlayer
              • Sep 2005
              • 2069
              • Silver Creek, MN
              • 1968 Mustang
              Check for a fuse. I had a fuse go last year. Popped it like 5 times, then it stopped failing.
              the WakeSlayer
              • wake4life6
                • Mar 2009
                • 218
                moved the impeller around no problem with sticking. Checked the fuse over and over no popping. no noise at all
                2006 210 SAN! TE
                • jward
                  • Feb 2008
                  • 620
                  • Sweet Home Alabama
                  • 03 SANTE 04 SANTE
                  Get a long piece of speaker wire or something like that and connect it to the wires of a ballast pump that is working. then connect it to the one that is not, just to see if it is a power issue.
                  • wake4life6
                    • Mar 2009
                    • 218
                    okay finally got it to run tapped it with a screw driver finally kicked on without the impeller in but just barely runs and keeps kicking the breaker sound nothing like the others. Just weird because it ran just fine filling it but now barely anything ?
                    2006 210 SAN! TE
                    • wake4life6
                      • Mar 2009
                      • 218
                      anybody know what this means is the pump dead just weird cause it was working fine now its barely running?
                      2006 210 SAN! TE
                      • WakeSlayer
                        • Sep 2005
                        • 2069
                        • Silver Creek, MN
                        • 1968 Mustang
                        Is this a saltwater boat? Just noticed where you are located, possible internal corrosion issue?
                        the WakeSlayer
                        • wake4life6
                          • Mar 2009
                          • 218
                          Fresh water only impellers look brand new only 35 hours on the boat
                          2006 210 SAN! TE
                          • d_nodixon
                            • Sep 2008
                            • 475
                            • Hammond, LA
                            • 2013 SAN 230
                            Boat motor running?? One of my pumps did run the same unless the motor was running.
                            2013 SAN 230
                            2006 SSN 210 (SOLD)
                            • JUST-IN-TIME
                              • 293
                              • ON YOUR BOAT
                              what is the model number of he pump
                              if these fill and dump he ballast, run the yellow impellers
                              they had problems with them running both ways
                              HUMAN BUILT = HUMAN FIXED
                              switchbait.com
