Where can I buy these. And any info on doing this i suck at working on stuff any advice or forum links would be appreciative
2001 Super Air Nautique
Python Powered
100 Amp Alternator
Dual Batteries
Many upgrades coming...
RE: changing impellers on my 2006 ballast
Check your breakers by your panel. They are prone to pop if your impellers are stuck over winter. You should be able to push them in an go now that you have freed up the impellers.2001 Super Air Nautique
Python Powered
100 Amp Alternator
Dual Batteries
Get a long piece of speaker wire or something like that and connect it to the wires of a ballast pump that is working. then connect it to the one that is not, just to see if it is a power issue.
okay finally got it to run tapped it with a screw driver finally kicked on without the impeller in but just barely runs and keeps kicking the breaker sound nothing like the others. Just weird because it ran just fine filling it but now barely anything ?2006 210 SAN! TE
