I just bought a slightly used 03 SAN and I have ordered a Mako Tower Light/Speaker bar. I know what to do as far as wiring the speakers but I am not sure how the lights will wire up. I don't have the bar yet, it is still shipping, I just wanted to get some input. Will I have to buy and add separate switches for the lights or how is the best way to wire these things. Thanks
I have a little bit of experience with this, as I have just recently had my tower lights rewired. I was continually blowing the main fuse for my lights, and I thought for sure I had a short somewhere inside the tower. It turned out that the lights were pulling too much power for the single wire leading from the battery to the switches to handle. I ended up replacing the main wire with two thicker wires (one for the lights facing forward, one for the lights facing rearward). This setup worked flawlessly over the past week, and I an sure it fixed my problems.
Mine are wired directly to the battery, with two switches mounted under the dash (one for the forward lights, one for the rear). From the switches, the wires run through the tower, and come out right by the light bar.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
