Fire extinguisher - 211
  • dgrimm
    • Apr 2009
    • 8
    I have been boating for decades (with other brands of boats) so I am embarrassed to ask this question....
    I just purchased a used 2008 SV-211 and I cannot find the fire extinguisher, which is required by state law. The manual makes no mention of it except that it is required.
    Can someone help me locate it? I see from a Google search that some models of this boat may have an automatic fire extinguisher system. How can tell if I have this system?
    Thanks in advance.
  • j2nh
    • Dec 2003
    • 628
    • Spread Eagle Wisconsin
    Fire extinguishers are mounted by the dealers when they are sold. Chances are yours was removed prior to your purchase. If you purchased from a dealer contact them and I am sure they will provide one at no charge, otherwise you can pick one up almost anywhere and mount it yourself. Make sure it is an ABC and Coast Guard approved (most are).
    Lets see some pics of the boat!
    2018 200 Team H6
    2009 196 Team ZR 409
    2005 196 Limited ZR 375
    2003 196 Limited Excalibur
    1999 196 Masters Edition
    1987 ProStar 190
    • jjgag60
      • Sep 2008
      • 165
      Halon Fire extinguisher is the best.
      If you have to buy one, save your money and get a Halon one. You want the old style that is bad for the Ozone. Hopefully you will never have to use it. The halon is the best because it will not ruin your electical and motor if you have to use it. If you use the standard type, you will spend hours and a lot of money replacing parts. Spend a little now and save a lot latter.
      • JUST-IN-TIME
        • 293
        • ON YOUR BOAT
        you get that on your skin or inhale it and your dead!
        HUMAN BUILT = HUMAN FIXED
        switchbait.com
        • Nautiquehunter
          • Jun 2008
          • 2080
          I thought Halon was banned years ago? I agree they are the best they work by replacing oxygen so the fire cant breath if you inhale it you cant breath either. The ABC type is basically baking soda I cant see how it can damage parts that are sealed to water? It does make a mess like dumping powder all over.
          • j2nh
            • Dec 2003
            • 628
            What?
            For an ABC Fire Extinguisher?
            (HMIS) Hazardous Material Identification System Ratings:
            Health: 1 Slight Hazard
            Flammability: 0 Minimal Hazard
            Reactivity: 0 Minimal Hazard
            I wouldn't eat the stuff but it is not considered harmful. It is a skin and eye irritant. Use does require a fair amount of cleanup as it sticks to everything.
            Do you mean HALON?
            HALON production is banned as it is hazardous to the ozone layer but it still can be purchased (recycled). Halon works by replacing oxygen in the area with a non-combustion supporting gas (HALON). Use in a closed environment does present a significant health risk as you can suffocate. Personally I would not use a Halon extinguisher in a boat as sufficient wind could disburse the gas. Face it, if your boat is on fire the least of your worries is going to be cleaning up the fire extinguisher residue.
            2018 200 Team H6
            1987 ProStar 190
            • DavidF
              • Sep 2004
              • 611
              • Austin, TX
              I do not think Halon is dangerous in an outdoor environment. I believe Halon was banned due to what stated above that it displaces oxygen to snuff the fire. In a closed room, that is bad if a person was in the room. Halon was used primarily in computer server rooms to keep water off the equipment. Problem occurred when the systems inadvertantly discharged while someone was in the room, or if a small fire broke out while someone was in the room and the person passed out due to the Halon before they could escape the room.
              Outside, it would seem almost impossible to displace enough oxygen to cause a problem. But, would work by displacign oxygen in the area the extinguisher was aimed.
              • j2nh
                • Dec 2003
                • 628
                Agree, can't see it being a suffocation problem outside. My concern in an outdoor environment would be a if Halon would be sufficient if there was a possibility of re-ignition.
                2018 200 Team H6
                1987 ProStar 190
                • Nautiquehunter
                  • Jun 2008
                  • 2080
                  With 40 gals of gas on board IMO the best fire extinguisher is a good exit plan.
                  • TravisFling
                    • Mar 2008
                    • 889
                    • London, Ohio
                    • 1989 Ski Nautique 2001
                    Or the submarine move...
                    Travis Fling
                    Choctaw Lake
