So I pulled my boat out of the garage with the sun deck up! It's a 2000 SAN with the hydraulic rear deck lift. The lift is still working but the bolts that bolt up to the deck pulled through and I have a small hole now. The bolts are bent so I know I need to replace those but their were nuts on the back sides of the holes holding the bolts in place. Any ideas on repairing this?
Tags: None
RE: I can
Drag dude.
I would grind it out a bit with a dremel to get rid of the gel anywhere you will have contact. Take a little off around the edges and countersink the holes a little. It will not stick to gel as good as the fiberglass.
Get this West Systems repair pack:
http://www.westsystem.com/ss/105-system-kits
You will need to figure out how they are anchored if at all. I am not sure how they are on mine, sorry.
Good luck.the WakeSlayer
1968 Correct Craft Mustang
RE: I can
Agree on the patch plate, it would look cleaner.the WakeSlayer
