I bought my boat about 3 years ago, I knew it had been in some salt water, and based on everything I could see it really just need some TLC. I am the kind of person who actually enjoys restoring stuff so I sort of liked the idea, and I got a pretty sweet deal.
This season I decided the carpet is due to go and I ordered new carpet for those who care it 40oz grey Nautique carpet from Nautique $17/linear foot 7 feet wide.
Okay so anyway, get the carpet up and that was a pretty simple task overall. Then to my dismay I see a area of the floor near the rear seat on the left side where there appears to be a slight hole. ****! Well I am pretty well versed in fiberglass fabrication so I am really not that concerned with mending it as the hole is about 1cm in diameter (1/2 inch roughly. It is not even really a whole as the fibers between are still in tact. I proceed to scope out the rest of the floor, and everything else is good.
As I look closer I notice the floor which is fiberglass is even from side to side, however not flat. There are slight waves in the fiberglass. I think wtf? Then I stop and say no way did Nautique do a crap job on this. I go home and ponder then call a bunch of boat shops they all say the hole could have happened from maybe an anchor or something - I buy that.
The waves however sort of like warping is not a characteristic of fiberglass nor Nautique.... So today I decide let me look a little closer, perhaps it is the stains of the glue marks that give the perception of waves? Nope there are waves - huh? So I then proceed to pick at the hole. Nautique said if the foam inside is in good then just mend the hole. Well the hole is now about 3 inches wide (for those who are not fiberglass versed this is not a bid deal at all).
What I found odd is that the fiberglass is set around what looks like a thin sheet of balsa. It could be plywood, but the wood is way too airy in my opinion to be plywood. I have searched the forums, I don't know if this is normal? Is a fiberglass floor basically insulated balsa? Seems odd to me if it is.
When i do a knock test on the floor the sound is much different in the area where the wood is versus other parts as well. It appears perhaps there may have been a repair at some point; however it is on both sides of the engine bay as well. Now before I go and start tearing my 3" hole into a 1 foot hole and so on, I want to know what the **** I am dealing with.
I feel that what occurred is the balsa got wet and expanded and sort of ballooned the fiberglass causing the waves. If so, is this a "real" cause for conce
