hey guys, i went out totay and every thing was good for a hour and a half.. my first run was good and then the second run the boat would go only up to 12mph and then suttered like no power but will idle at 12???? and the engine ck light came on. i ck'ed the rotor and cap and looks like new. any of you ever had this happen ? i have a 02 sante. any help would be great... thanks
Boat won't go up to speed
Tags: None
RE: boat want go up to speed
I think the computer is kicking into limp home mode. I don't have any idea what the underlying cause is, but I'm pretty sure, that's what is happening to you.
BKH2001 Super Air
Doesn't the knock sensor do some funny stuff like that if it is disconnected or bad ?the WakeSlayer
1968 Correct Craft Mustang
I've had the same issues with fuel filters and with a temp sensor. The temp sensor would send a signal to the alarm of overheating but the guage and temperature was correct and OK.
just went down to WL Marine and talked to David and he belives that it is the oil sensor so i got it and i will try that today i hope, also replacing thermostat and the 2 hose's coming off the housing. will let you know how it goes thanks
hey guys to let you know it was the oil sensor that was bad and every thing else is great ... thanks to david at WL marine..!!!
