ski nautique 2001 propellor
  • Nickyd
    • Aug 2004
    • 3
    Hi There..
    I have recently purchased a Ski Nautique 2001 here in South AFrica. It has been suggested that I purchase a 4 blade propellor , preferably a 14"x14" RT. I do not know whther this is an accurate spec, if so where in the USA could I purchase it OR if not what is the correct propellor for my nautique. Please can you assist with advice and or suggestions?
  • marks
    • 9
    Hi Nickyd,
    The propellor size will depend on which transmission you have and the brand of prop you want to purchase. My 2001 has the PCM 1.23:1 tranny. The stock prop was a Federal 3-blade 14x16. A few years back I changed it to an OJ Force 4-blade 13x15. I lost a little top end speed but gained some low end power. The change helped a little with holding the boat at wakeboard speeds. There have been some favorable reviews of the new Acme props. I believe that is what Correct Craft is putting on the new boats. Supposedly they have a 3-blade that outperforms the 4-blades. Check out CorrectCraftFan.com. There is a review of it there. www.skidim.com carries both Acme and OJ props. You can contact either company directly to determine the correct size prop for your boat.
    http://www.ojprops.com
    http://www.acmemarine.com
    If you are unsure what transmission you have, the type is encoded in the engine's model number. That's assuming you have the original engine. I believe the choices are Borg Warner 1:1, PCM 1:1 and PCM 1.23:1. I don't think the PCM transmission were available until around 1988 or 1989.
    Hope this helps,
    Mark
    • FUN-9C1
      • Jan 2004
      • 16
      • southern Maine
      You mean year 2001 or model 2001? If you meant the latter, what year is it? Someone correct me if I'm wrong, but I'm 99% sure all 2001's ('82 or 3 to '89) were 13x13's, RH. If you can't wait for answers here, skidim can tell you also. I'm "this close" to buying a 4 blade for mine. I have a reman 3 blade and I think they messed up. Top speed went from about 43 to 38...
      \'86 SN
      Jet Skis and Tubes are what\'s wrong with this country!
      • 882001
        • Aug 2003
        • 353
        • clear lake texas
        89s had a different tranny,so
        there is a really good article
        http://www.correctcraftfan.com/forum...N=1&FID=7&PR=3
        1988 Ski Nautique \"2001\"
