Engine Drain Plugs
  • LakeWI
    • Apr 2009
    • 1
    • Poynette, WI
    Engine Drain Plugs
    Hi,
    A friend winterized by 1998 Ski Nautique last year. I have insalled 4 drain plugs but have what looks like a 5th plug and I am unable to locate the location. I put back the two on the back of the manifolds. One on the driver's side of the engine block and one underneath a pipe in front of the blocik. Am I missing a location or do I only have 4 engine drain plugs? Thanks.
    LakeWI
  • bchesley
    • Feb 2006
    • 1252
    • Tyler, Texas
    RE: Engine Drain Plugs
    There is one on each side of the block. They are mounted in the same spot on both sides.
    2001 Super Air Nautique
    Python Powered
    100 Amp Alternator
    Dual Batteries
    Many upgrades coming...
    • pj
      • Oct 2003
      • 323
      • Rochester, MN
      • 1991 SN 1996 SN
      The fifth one goes at the bottom of what looks like the "sink trap" on the way to the water pump.
      Once you have tasted flight, you will forever walk the earth with your eyes turned skyward. For it is there you have been and there you will long to return. - Leonardo De Vinci
