Just got the boat out of storage and were gonna add a sound system. I saw a thread somewhere on how to run the wires up through the FCT. I will be installing 4 Rockford Fosgates on the tower. I did a search and can't seem to find it again. Our boat is a 2001 Sport Nautique with an Air Package. Any help will be much appreciated!
RE: Wiring a 2001 Flight Control Tower
Not sure what thread your talking about but it's a piece of cake. All you need is a shop vac, some string, and some masking tape. Unwind a bunch of string, tie a not in the end. Take a little piece of masking tape and fold it over the end to increase the surface area of the string. I think when I did it, I started at the farthest one away. If you have already drilled all the holes (as I did), you will have to tape those up. Then put the vac on the open end and turn it on. You should see the string getting sucked up into the tower. In a few seconds, it should come out the other end.
Rest of the pics can be found here....
http://planetnautique.com/index.php?...;p=66866#66866
