This is my first time changing the filter on the FCC since i bought the boat. I understand there is supposed to be a lock nut (so 2 nuts?) on the bottom of the bowl for draining before i take off the canister. The problem is I only have 1 nut that I can't remove because it just spins with the shaft. After standing upside down on my head for a better look, there appears to be one threaded shaft inside of another threaded shaft? I can see how there may have been a lock nut on the smaller of the 2 shafts. I tried to put a nut on the smaller one, but it wasn't possible because there is just 2 threads to catch the nut.
Can I try to unscew the bowl without removing this? What kind of problem do I have here?
