2003 Excalibur Stalls During Idle, delays restarting
  • jaybird
    • Oct 2008
    • 516
    • North Alabama Lake Weiss
    Recently my Excalibur has stopped 4 to 5 times while idling over 3-4 days. When attempting to re-start engine turns over but does not immediately start. Once it took 5-6 attempts to re-start. This only happens at idle and the boat is running great. FCC filters were changed 30 hours back. I have drained the FCC no water, checked pressure at fuel rail and it’s fine, around 50 PSI when ignition is turned on, during starting and while running. I can here FCC pump run when ignition is turned on.
    Can the idle control module or anti-siphon valve affect or cause hesitation when starting?
    I plan to take the fuel pressure gauge with me and next time it stops I will check pressure when I attempt to restart. I just feel the fact that it quits only during idle and then does not immediately re-fire should be a clue as to the culprit, just not sure what. :?: Any Ideas?
    2012 Team Ski Nautique ZR409
    2011 Sport Nautique 200
    2008 SANT 230
    2003 Air Nautique 226
    1988 Martinique
    1979 Nautique
    1978 Tique
    1976 Tique (First New Boat)
  • jaybird
    • Oct 2008
    • 516
    2008 SANT 230
    1988 Martinique
    1979 Nautique
    1978 Tique
    • jaybird
      • Oct 2008
      • 516
      2008 SANT 230
      1988 Martinique
      1979 Nautique
      1978 Tique
      • j2nh
        • Dec 2003
        • 628
        • Spread Eagle Wisconsin
        Jaybird.
        Had something very similar on my 03 excalibur. Engine would fire just fine when cold, ran great, but did not want to restart when warm. It would, sometimes you would have to pump the throttle but it would start.
        Dealer sent me some parts which included the R020019 Sender and I think a relay (been a few years but I still have the old sender with PN). Problem solved.
        Not sure what the Sender checked but was on the top of the manifold.
        2018 200 Team H6
        2009 196 Team ZR 409
        2005 196 Limited ZR 375
        2003 196 Limited Excalibur
        1999 196 Masters Edition
        1987 ProStar 190
