Rear Plug
  • 99SNATX
    • Apr 2009
    • 5
    Rear Plug
    As a pulled the rear plug the other day I noticed that there is a nickel and some kind of cotter pin in the drain path. Is there a quick way to get to these so they can be removed?
    - Travis
  • gride300
    • Apr 2008
    • 1356
    • mobile, al
    RE: Rear Plug
    shop vac
    • WakeSlayer
      • Sep 2005
      • 2069
      • Silver Creek, MN
      • 1968 Mustang
      RE: Rear Plug
      Is this really a question?
      the WakeSlayer
      1968 Correct Craft Mustang
      • CradGen2
        • Aug 2020
        • 1343
        • Horseheads NY
        RE: Rear Plug
        It was posted in the Maintenance &amp; Technical Questions area, so must be a questions!
        Personally I would move all the boards and junk out of the way and reach back there and get the items. Arms might come back a little bloody, but you will have a clean baby. The little prices we pay to raise our children right.
        • Nautiquehunter
          • Jun 2008
          • 2080
          RE: Rear Plug
          1- Remove the interior and accessories from the rear of the boat.
          2- Remove the engine and trans.
          3- Suit up in a EPA approved full body coveralls.
          4- Remove nickle using sterilized surgical instruments.
          • jward
            • Feb 2008
            • 620
            • Sweet Home Alabama
            • 03 SANTE 04 SANTE
            RE: Rear Plug
            HaHa. thats pretty funny Nautiquehunter. So much for the old saying. "No question is a dumb question"
            • WakeSlayer
              • Sep 2005
              • 2069
              • Silver Creek, MN
              • 1968 Mustang
              RE: Rear Plug
              I guess. I just thought that it was extraordinarily obvious to reach down there and grab the stuff. Sorry. Bring some paper towels and wipe out the bilge while you are down there too. As long as you are going to get your arms stuck, you may as well get more than $.05 out of doing it.
              the WakeSlayer
              • Quinner
                • 2246
                • Correct Crafts
                RE: Rear Plug
                Sounds like he is referring to the Rear plug in the transom, not the bilge drain.
                Use a coat hanger or something to push the nickel as far forward as possible, if you can't see it or reach it, remove the doghouse and rear floor section (assuming you have an inboard) you should see it then.
                If this fails refer back to Hunters Post.
                • 99SNATX
                  • Apr 2009
                  • 5
                  RE: Rear Plug
                  yes, I am refering to the rear plug in the transom..just wanted to know if there was a quick way to get that stuff without pushing it forward...on the other hand I appreciate all the great suggestions...ill be sure to pull out my coveralls this afternoon
                  • AuMDLST
                    • Apr 2007
                    • 870
                    • Orlando, FL (Butler Chain)
                    stuff
                    I would be wondering where the cotter pin came from.
                    2006 SANTE 210 (Pending Sale)
                    2005 206 TE (Previous)
                    • SkiTower
                      • 2172
                      • Clayton, NC
                      Re: RE: Rear Plug
                      Don't forget the tanks! Yellow_Flash_Colorz:
                      2007 SV211 SE
                      Tow Vehicle 2019 Tundra
                      Dealer: www.Whitelake.com
                      • TravisFling
                        • Mar 2008
                        • 889
                        • London, Ohio
                        • 1989 Ski Nautique 2001
                        RE: Re: RE: Rear Plug
                        Poor guy.
                        Travis Fling
                        Choctaw Lake
