Extra Battery
  • krt
    • Sep 2008
    • 231
    • La Verne
    • 2008 210 SAN TE
    Extra Battery
    Anyone add a battery or two to a '08 210? Looking for location ideas.
    thanks
    2008 SAN 210 TE
    1997 Ski Brendella (sold)
  • gride300
    • Apr 2008
    • 1356
    • mobile, al
    RE: Extra Battery
    so i'm guessing you already have two? you could put one under the flip up passenger seat or in the bow on the port side under the seat. why do you want another battery
    • krt
      • Sep 2008
      • 231
      • La Verne
      • 2008 210 SAN TE
      Re: RE: Extra Battery
      Yes I have two, want to add at least one more, like you said on the port side if possible.
      2008 SAN 210 TE
      • 8122pbrainard
        • Jul 2007
        • 255
        I always have to ask why? Loads? Alternator bad? Bling?
        • gride300
          • Apr 2008
          • 1356
          • mobile, al
          RE: Re: RE: Extra Battery
          depending on our storage space i would put it somewhere under the port flip up seat, but if there is a sub in there you may have some space issues. what speaker set up/amp/led or anything do you have on there that requires a 3rd
          • krt
            • Sep 2008
            • 231
            • La Verne
            • 2008 210 SAN TE
            Adding 2nd amp and we like to park and play the stero mid day. I guess I can try it all 1st and see how long one battery will last when parked. I plan to turn the 2 postion switch to one battery or the other while parked.
            2008 SAN 210 TE
            • gride300
              • Apr 2008
              • 1356
              • mobile, al
              trust me man, i have 4 amps in my boat and running it on pos. 2 it last a long time. with your setup you'll be more than fine. save your $. at the least buy a ctek charger from earmark. that will keep your batt. tip top.
              • krt
                • Sep 2008
                • 231
                • La Verne
                • 2008 210 SAN TE
                Guess I will give it a try with the factory set up then... thanks
                2008 SAN 210 TE
