I have a 2005 211 with the zr6 engine. I have been out all day and started perfect all day. went to start it to put it back on the trailer and it wont start. Engine will turn over but will not fire. the boat runs on LPG and I can not hear any soleinods click. all so the hours on the dash have gone to zero. has any body else had this problem ?
RE: 211 wont start
batterys are good, has two batterys, engine turns over but will not start, not sure if it has a spark, seems to me that no gas is getting through,as no soleniod clicking.not sure if this is ran of ECU.and also why dashboard showing no hours?
this is the first time I have used the boat after the winter lay up, may be moisture in ECU?
would like the software to plug computer in, is there any where I can get this?
RE: 211 wont start
There should be a couple connections at the bottom of your fuel pump. Check those. I had a friends boat not want to start despite turning over, because one was loose.
Also, can you check for spark?the WakeSlayer
1968 Correct Craft Mustang
RE: Re: RE: 211 wont start
yes it is zero hours,went through the rest of the memory and all zero. am going to check the sparks see if we have one. all so check all conections, as I am getting no LPG, we don,t have petrol just LPG. on the gas system I have no soleniods working so getting no gas. I was wondering if these are controled off the ECU ? as the gas system is an extra wouldn't have thought the ECU controled the fuel. hoping it may just be some moisture in the ECU with being layed up over winter. will let you know what I find, thanks for your help
went up to the boat this morning, soon as I turned on the power, engine came back on the dash, enige started and ran for a few mins, then cut out. zero hours no sparks and no gas. when discounected ECU i could tell no diffrence
Re: RE: Re: RE: 211 wont start
Originally posted by gride300oh no worries i know you werent being mean/rude. of all the posts i see on here yours, mikeski, earmark, and wetsounds are the ones i heed the most.
I try to add value in return for the help I get from the others. There are several other good posters in addition to the ones you named. They know who they are.
AirTool
