211 Transmission service help??
  • 2WIN
    • Mar 2005
    • 42
    • Galesburg Illinois
    Hey all, It's been a while since I was on here last but I am looking to drop the boat in the water for it's 4th season and haven't yet replaced the transmission fluid. The boat has very low hours on it but I thought it would be good to replace.
    Am I getting into something I should let the dealer handle or is this something I can do? I have the vacuum oil remover that I use on the engine. Will it work here as well?
    What fluid does it take? Dexron? From what I did read it looks like dino oil is the way to go. Is there a filter to replace like a car?
    I searched on the subject but found nothing specific to the late model 211's.
    Thanks for any help you can offer.
    Chris
    Really wishing my dealer could have gotten me a service manual...
    • 2908
    RE: 211 Transmission service help??
    Need a manual?
    Click here: http://www.planetnautique.com/index....load&cid=1
    • 2WIN
      • Mar 2005
      • 42
      Sweet! Hopefully the 2006 manual will work as the 2005 211 manual isn't there.
      Thanks for the link!
        • 2908
        Can't remember if 06 or 07 was the year of the tranny and/or v-drive change?
        Gotta run, if you still can't find it by tomorrow PM me and I will pull up my 2005 211 boat cover and see what it says on my trans for fluid. For some reason I vaguely recall that my manual is not correct with respect to trans or V-drive fluid.
        mikeskiw@gmail.com
        • clubmyke
          • Sep 2004
          • 414
          • so cal
          look on the transmission - it will have it on there (btw, the manual was wrong).
          • nms1991
            • 477
            The type of trans fluid to use is Dextron III/Mercon II trans fluid and you have to pump it out through the dipstick hole and there is no filter you can change. And they did change the V-drive in 07'.
