leaky port ballast tank on 211 - any ideas?
  • clubmyke
    • Sep 2004
    • 414
    • so cal
    my port side ballast tank is leaking on my 05 211- i can hear dripping when it is filled up (the carpet is dry underneath).
    any ideas before i take it apart ?
    thanks,
    mike
  • WakeSlayer
    • Sep 2005
    • 2069
    • Silver Creek, MN
    • 1968 Mustang
    RE: leaky port ballast tank on 211 - any ideas?
    My friend has an 05 that is in the middle of a very slow system upgrade. He always had a bunch of excess water in his. Turned out that the neck on the bilge pump on the bottom side had cracked 3/4 of the way through. There would be no way to fix this without completely replacing the pump. We saw it after the tanks were pulled so not sure if there is a way to do it without removing the tank. Hopefully this helps you.
    the WakeSlayer
    1968 Correct Craft Mustang
    • nms1991
      • 477
      I also would check the empty pump on the tank as the pump sometimes has a problem cracking at the seams.
      • WakeSlayer
        • Sep 2005
        • 2069
        • Silver Creek, MN
        • 1968 Mustang
        by bilge pump, I meant the drain pump on the bottom of the tank. They are just bilge pumps.
        the WakeSlayer
          • 2908
          hmmm, I think you run pop bags on top of the tanks right? You might have a little crack in the tank somewhere near a corner? Pull it out, I have had mine out, it's not awful bad, just a little pita. Use a heat guy to remove the hoses. The starboard tank is easier to get out but it's not that much harder.
          • clubmyke
            • Sep 2004
            • 414
            • so cal
            Thanks for the help everyone- turned out to be a cracked pump fitting.
              • 2908
              make that HEAT GUN to help remove hoses
