2007 SANTE 210 Oily Sheen in Bildge?
  • txrn75010
    • Aug 2007
    • 21
    • Dallas
    I was preplexed @ first discovery, no sign of oil leaks so thought it was maybe fuel?...that system checked out fine as well....Well today I found the source>>>>there is a small pressure brelief vale, I believe, @ the top of the PCM tranny housing (not the vdrive) close to mthe cooling hose outlet.....MY questiion is should i be worried ab this?....no loss pwr or slippage or anything noted....my quess is that it got a little too hot in the case..but why?....do i need to change the oil cooling unit im gonna change fluid and monitor
    Any advice education etc is greatly appreciated
    Life is Short/Ride HARD! >>> 07/08 SANTE 210
  • thedude
    • Apr 2007
    • 451
    • SW PA
    RE: 2007 SANTE 210 Oily Sheen in Bildge?
    My 03 has oil a bit of oil in the bilge most of the time, I think the V-Drive leaks a tiny bit of oil from the gasket. I believe this is a well documented issue on older SAN's. I'd just check your fluid levels regularly.
    • bchesley
      • Feb 2006
      • 1252
      • Tyler, Texas
      There are many ways it could have gotten there. The dealer could have overfilled it? Spilled some when they did the service? I would not be too concerned with it as long as your fluid levels stays pretty constant.
      2001 Super Air Nautique
      Python Powered
      100 Amp Alternator
      Dual Batteries
      Many upgrades coming...
