Is a Ramlin Swing Away Tongue Reversible?
  • ksarbau
    • Mar 2008
    • 52
    • Indianapolis, IN
    • 2016 G23
    I have an '07 Ramlin trailer with a swing-away tongue. Right now the tongue pivots and swings toward the driver's side of the boat. The previous owner mounted the spare tire on that side of the trailer so I can only swing it 45 degrees or so before I hit the spare.
    Can I swap the removable pin and the bolt so that the tongue swings towards the passenger side of the boat? It certainly looks like it should work, just wanted to see if that's allowed before I take it apart.
    Thanks! Keith
    2007 Air Nautique 211
  • ffmedic74
    • 835
    • Lexington, KY
    RE: Is a Ramlin Swing Away Tongue Reversible?
    Yes, just put the bolt on the other side. If you have a spare tire, it might get a bit in the way though.
    • SkiTower
      • 2172
      • Clayton, NC
      Re: RE: Is a Ramlin Swing Away Tongue Reversible?
      That's why he wants to flip it, to get it away from the tire. However, take a look at your jack too...
      2007 SV211 SE
      Tow Vehicle 2019 Tundra
      Dealer: www.Whitelake.com
      • AuMDLST
        • Apr 2007
        • 870
        • Orlando, FL (Butler Chain)
        RE: Re: RE: Is a Ramlin Swing Away Tongue Reversible?
        The jack and (small detail) the stop nut welded to the swing side.
        2006 SANTE 210 (Pending Sale)
        2005 206 TE (Previous)
        • Onevw2go
          • 179
          • Wisconsin
          this is kind of a dumb question, but, Can the spare tire be switched to the other side? sounds like less work?
          • ffmedic74
            • 835
            • Lexington, KY
            Yes the spare can but it might get in the way of the jack.
            • ksarbau
              • Mar 2008
              • 52
              • Indianapolis, IN
              • 2016 G23
              Re: RE: Re: RE: Is a Ramlin Swing Away Tongue Reversible?
              I want to avoid moving the spare if possible because I think the spare tire mount has marked / rubbed the paint under the bracket / bolts. Would prefer not to expose that.
              Moving the spare would be a more logical thing to do though :-)
              • AirTool
                • 4049
                • Katy, Texas
                RE: Re: RE: Re: RE: Is a Ramlin Swing Away Tongue Reversible
                I'll try to look at my 07/08 trailer tomorrow night. The jack whould be on the tow vehicle's driver side and the spare on the other.
                The kit on this thread looks reversible. http://www.planetnautique.com/index....ght=tongue+kit
                • AirTool
                  • 4049
                  • Katy, Texas
                  I checked my trailer today and the pin is on the boats driver side and it swings to the boat's passenger side.
                  I ordered the trailer with the spare...maybe that's why they set it up to swing to port.
                  AirTool
                  • ClemsonDave
                    • Oct 2004
                    • 659
                    • Glen Allen, VA
                    • Ski Nautique 200
                    I'll take a look at mine today, but I wonder if you could make the tongue removable? Replace the pivot bolt with another pin. Put a quick disconnect on the wires. Remove the bow stop and the tongue would not be that heavy. Here is a picture of mine, but can't see the bolt very well.
                    Promo Team member
                    1999 196
                    2010 200 Team 2010 200 Team
                    2011 200 Team 2011 200 Team
                    2012 200 Team - 2012 200 Team
                    2013 200 Team - 2013 200 Team
                    2014 200 Team - 2014 200 Team
                    2015 200 Team - on the way
                    • Hollywood
                      • Sep 2003
                      • 1930
                      • WIIL
                      Sure Dave, you'd also need a fitting for the brake line. My buddy's 99 Sanger has a removable tongue. It is a factory Sanger trailer.
                      • AirTool
                        • 4049
                        • Katy, Texas
                        Re: RE: Re: RE: Re: RE: Is a Ramlin Swing Away Tongue Revers
                        AirTool
                        I checked my trailer today along with my brain. Brain is critical condition and failing rapidly.
                        Trailer tongue swings to the boat's starboard side ...side with spare. Still looks reversible or dual pinned is okay. There is a bumper on the side that swings...so If I switched it...no bumper to prevent paint damage.
                        • jward
                          • Feb 2008
                          • 620
                          • Sweet Home Alabama
                          • 03 SANTE 04 SANTE
                          RE: Re: RE: Re: RE: Re: RE: Is a Ramlin Swing Away Tongue Re
                          When I bought my boat I got it home and backed it in the garage to find out that the pin was siezed up and there was no getting her out. So I just pulled the bolt on the other side and swing it on the pin. No problems so far.
                          So to answer your question, yes it is reversible
