installing new skins on rear hatch
  • hdultra
    • May 2007
    • 121
    • Alabama
    Just recieved my skins and went to buy some stainless staples from lowes. When I started reading the box it said not for marine use. Do you think it means not to put under water or maybe even in salt conditions. I boat in central Alabama so no salt. What are some of y'alls opions on this. Or whats a store I can get proper staples?
    2010 SANTE 210
    2004 SANTE 210
    1986 2001
    1989 2001
    1992 SNOB
    1987 2001
  • DavidF
    • Sep 2004
    • 611
    • Austin, TX
    RE: installing new skins on rear hatch
    If they are indeed stainless steel, you will be okay. There are different grades of SS and some grades handle the marine environment better than others. But, like you said, no salt and not under water. So, you are not really in a marine environment, but more like a back deck/patio environment. They will work fine. Or, you can use Monel staples that are even more corrosion resistant than the the SS staples. But, they are softer and tend to bend when driving into harder materials. If your deck is like mine, it has the plastic strip screwed around the perimeter of the hatch for stapling. If so, no problem using Monel staples.
    • hdultra
      • May 2007
      • 121
      • Alabama
      Thanks I might try to find some of the monel staples and if no luck just use the stainless. Thanks again
      2010 SANTE 210
      2004 SANTE 210
      1986 2001
      1989 2001
      1992 SNOB
      1987 2001
      • gride300
        • Apr 2008
        • 1356
        • mobile, al
        i just noticed a small 1.5"-2" tear on my engine hatch. it has come apart at the seams. can i just sew it back together or is there another route?
        • hdultra
          • May 2007
          • 121
          • Alabama
          My dad had some seems sewed but he had to take the skins off and take them to a shop. I also had some sewed up on my 86 but once again had to remove them. As long as the material is still soft and in good shape it should be fine to get repaired.
          2010 SANTE 210
          2004 SANTE 210
          1986 2001
          1989 2001
          1992 SNOB
          1987 2001
