Can you run a boat without a prop
  • jjgag60
    • Sep 2008
    • 165
    I need to fix a noise coming from inside my boat while in gear at a specific rpm (under 2,000). I thought about removing the prop and backing the boat and trailer into the water and then starting it. Does anyone know if you could damage anything by doing this? By leaving it on the trailer i can spend more time finding the noise.
    RE: Can you run a boat without a prop
    You will be fine. Do not let the motor over rev. It might be that the noise needs the thrust load of the prop, so do not be surprised if the noise goes away.
    • jward
      • Feb 2008
      • 620
      • Sweet Home Alabama
      • 03 SANTE 04 SANTE
      Would it not be the same to just rev it in nuetral?
      • WakeSlayer
        • Sep 2005
        • 2069
        • Silver Creek, MN
        • 1968 Mustang
        What noise?
        the WakeSlayer
        1968 Correct Craft Mustang
        • AirTool
          • 4049
          • Katy, Texas
          If you have cruise with the rpm feature, use it.
          • jjgag60
            • Sep 2008
            • 165
            without a prop
            Thank you for the suggestions. I think Daniel is right, my noise is only in "gear" so without the prop the noise may go away. I will try the RPM cruise and then have someone drive, while I look and listen. Thanks everyone.
            • harddock
              • Apr 2008
              • 292
              • toontown E-9
              RE: without a prop
              It problably won't plane off but go for it.
              • AirTool
                • 4049
                • Katy, Texas
                Re: without a prop
                Get a stethoscope from the auto parts store....don't stick the rod or you body parts in rotating engine parts.
                http://www.sears.com/shc/s/p_10153_1...&amp;sbv=Lisle
