My perfectpass was off by about 4 mph in wakeboard mode so I attempted to do a speedo adjust option. After I did this now perfect pass will not engage. It shows the set speed on the screen but to the right where it should show the actual boat speed it says .1 and will not engage. The paddle wheel turns freely and it works fine in RPM mode. I beleive I just messed up a setting more than likely. I have the wakeboard pro 6.5n with servo motor. Has anyone ever ran into this issue?
- Jul 2003
- 2908
- San Francisco, CA
- Current 2005 SV 211, due for upgrade! GS22 or GS24 perhaps? Previous
RE: Perfect Pass not working in Wakeboard mode
I find the speedo adjust to be counter intuitive. Likely you lowered the speedo by 4 so you would have to overshoot the speed to get it to engauge? Set it for something like 8mph and see if you can get it to engauge. It's also possible that your paddle wheel is shot and not providing a clean signal? I am guessing, call perfect pass, they have great customer support.
You may have over adjusted the speedo function and you may have to do a system reset. The way to do this is to hold down the menu ,up, down buttons while you are turning the boat on and hold until it says system reset y/n. Then run your boat and make sure you put in a crew weight before you test and check it against a gps unit to make sure it is accurate.
