1990 Sport Nautique Exhaust
  • cuwakeboard
    • Apr 2009
    • 11
    • Loveland, CO
    I recently purchased a 1990 Sport Nautique. There seems to be a abnormal amount of exhaust coming from the transom at cruising speeds. This does not happen at an idle, only at the higher speeds. Is this normal, or am I just paranoid?
    Thanks, Eric
  • 8122pbrainard
    • Jul 2007
    • 255
    RE: 1990 Sport Nautique Exhaust
    Eric,
    I think your paranoid! When you say "abnormal amount", is this white "smoke"? If so, it's water vapor being condensed by the cooler ambient air temps you are seeing this time of the year.
    • TravisFling
      • Mar 2008
      • 889
      • London, Ohio
      • 1989 Ski Nautique 2001
      I was just going to say the same thing... remember - White = steam (vaporized water from the heat of the engine) and is perfectly normal. Blue means you're burning oil, and isn't horrible (you can drive back to the dock, being mindful of your pressure.) and Black means you're burning excess fuel (not combusting in the cylinder, but burning later in the stages of stroke/exhaust.)
      White "smoke" is most notable at cruise as the engine's producing enough heat to vaporize the water, but the air "eddy" is just right to allow it to hang around. At quicker speeds the airflow causes the vapor to disperse too rapidly to be noted too much.
      Travis Fling
      Choctaw Lake
      • cuwakeboard
        • Apr 2009
        • 11
        • Loveland, CO
        Thanks guys. I have one more question -
        I bought the boat from a guy located close to Lake Powell (elev = 3700) and will use it extensively in the rocky mountains (elev = 5000-7000). Do I need to due a tune-up to account for the change in altitude? Thanks.
        • AuMDLST
          • Apr 2007
          • 870
          • Orlando, FL (Butler Chain)
          I'm thinking you may want to have the carb adjusted for the altitude difference (I believe less oxygen would make it run on the rich side) - Someone else with better carb knowledge will most likely post with a definite answer.
          2006 SANTE 210 (Pending Sale)
          2005 206 TE (Previous)
          • AirTool
            • 4049
            • Katy, Texas
            I would say that if it idles smoothly to not mess with it.
            • AirTool
              • 4049
              • Katy, Texas
              Otherwise, without looking at the carb....you would probably have to change the jets.
              I don't see any other "tune up" adjustments to compensate for the low air density.
