Oil and oil filter recommended for Vortec 330 engine?
  • wsmith48
    • May 2009
    • 3
    I havn't had any luck finding the oil recommended for the Vortec 330 engine, does anyone have any recommendations? Thanks
    - Will Smith
  • Quinner
    • 2246
    • Correct Crafts
    RE: Oil and oil filter recommended for Vortec 330 engine?
    For an Excalibur use 15w40, I use the Shell Rotella, others are available. Most likely you have the remote oil filter which actually uses a standard Ford filter, FL1a or equivalent, I use the Motorcraft brand, you want to avoid the Fram from what I have read.
    • wsmith48
      • May 2009
      • 3
      Ok, thanks for the help.
      • jos
        • 154
        • Netherlands Boxtel
        The Fram fits my remote.
        Others are 0,2" longer and collide the manifold when you slide it on.
        Should be straight for the slide on.
        • MacedayDave
          • Oct 2004
          • 70
          • Norris Lake - Andersonville, TN
          • 2005 SN196LE
          You can also use the AC-Delco PF-2 oil filter.
          • AirTool
            • 4049
            • Katy, Texas
            The 15w40's are over in the diesel section....but they do meet the API spec for gas engines.
            • BP22
              • Jan 2007
              • 248
              • Covina, CA
              • 2006 Super Air Nautique 210
              Re: RE: Oil and oil filter recommended for Vortec 330 engine
              Me too and it is all readily available at your local Wal Mart.
              Brandon
              2006 SAN 210
              • AirTool
                • 4049
                • Katy, Texas
                RE: Re: RE: Oil and oil filter recommended for Vortec 330 en
                I've been buying the wix because they are good filters and also painted glossy BLACK. I take the label off with some goo gone....looks sick when you open the clamshell and notice the discrete black filter.
                I think mikeski gave me the idea.
                I use the Mobil Delvac 1x00 oil.
                  • 2908
                  That's a wix 51515, available by the case on e-bay. Buy a case keep enough for a couple years and share the rest with your friends.
                  Note the remote filter mount uses a Ford specific filter. Kind of wierd using a Ford filter on a Chevy motor but PCM stuck with the same remote filter plate when they switched from Ford to Chevy.
                  I use Chevron Delo 15w-40 available from Costco.
                  • WakeSlayer
                    • Sep 2005
                    • 2069
                    • Silver Creek, MN
                    • 1968 Mustang
                    The Ford filter makes the Chevy go faster.
                    the WakeSlayer
                    1968 Correct Craft Mustang
