switched 12v power
  • contour
    • Oct 2004
    • 20
    switched 12v power
    I have a 2009 sn 196 with the keyless ignition and looking for a "switched" 12v power source under the dash. I'll be running the power through a relay switch that will be able to turn off the heater when the engine is not running
    Does anyone know what color wire, or where I can find a "switched" 12v source under the dash??
    I do not what to poke around with a volt meter because of the bus electonics there
  • contour
    • Oct 2004
    • 20
    12v switched power
    the purple ignition wire at connector P2 of the gateway under the instrument pod of a Team/Limited or at the ignition switch of a signature
