70hp evinrude stalling
  • lr52924
    • Sep 2008
    • 11
    • Orlando
    • 2018 G23
    Originally posted by DavidF
    If the firing order was wrong, I would suspect you would be getting popping/backfires through the carb which can damage the rubber check vavle in the accelerator pump (I think I have that right).
    Finally, sputtering and no power could also indicate a bad coil pack (one of the two). PCM will make you switch to conventional ignition system rather than sell a coil pack to you. PCM will only sell the coil packs to TBI engine owners.
    The wrong firing order will not always cause a backfire or pop. A backfire will sometimes damage the power valve, but I believe Holleys have had built in protection for the last 20 years or so.
    Im still a little confused- I was sure that the last year for the Protec was 1994. 1997 should have a standard distributor if its a base carby motor.
