a couple of weeks ago, i set a code for my boat, and now i forgot it. any body know what i can do to get my boat started....im at the lake with no boat cause im an idiot!!!!
Don't you need the master-code in order to set the primary and secondary user codes? Use your master-code and you should be able to start the boat and reset the user codes.
If you don't know the master-code, you should be able to get it from your dealer (I'm assuming ...... if he knows you).
The master code is set by correct craft, and all you need to reset the primary code is the original primary code to reset it and you need the secondary code to reset the secondary code. Your local dealer if they know you can get your master code off the nautique dealer intranet with your hull number.
