I have a 1984 Nautique with a 1:1 Velvet Drive transmission. Just recently the prop started turning forward with it in nuetral. The transmission is not in gear and I can stop the shaft from turning with my hand. After this problem started I changed the fluid which still looked good and found now metal shavings in the bottom of the transmission. There was no debris in the transmission screen. I am using the correct ATF and the level is right were it needs to be.
Any help appreciated!
