boat will still not start
  • Bobby
    • Jul 2004
    • 87
    • Norman, OK
    engine will crank
    fuel pressure is at 41psi, pumps do activate when key is turned
    emergency killswitch has been bypassed
    has been spark tested - spark is good
    new starter/fuel relays have been installed
    checked computer test ground and it is grounded well
    FCC was full of clean gas when I pulled it off the other night to check for water
    why will it still not start and what is left to check out before i take it in to a mechanic and it's gone for the summer?
    1996 Sport Nautique w/ EFI GT-40
  • jaybird
    • Oct 2008
    • 516
    • North Alabama Lake Weiss
    RE: boat will still not start
    what year? What Engine? Is it turning over? Where did you check for a spark? If at the plugs, how many plugs did you check? Does it try to fire at all?
    If you have a spark and fuel pressure is good then the ECU must not be calling for fuel to the injectors. Sounds like problems with the ECU. You probally need to pull the ECU codes.
    2012 Team Ski Nautique ZR409
    2011 Sport Nautique 200
    2008 SANT 230
    2003 Air Nautique 226
    1988 Martinique
    1979 Nautique
    1978 Tique
    1976 Tique (First New Boat)
      Stay clear of moving things.
      If you put a fingertip on the fuel injectors, you should feel them vibrate as they are switched on and off. The engine will need to be cranked for this .
      Compression, Ignition, Fuel. Give an engine all three and it will run. Millions of engines prove that every day.
