Help needed with Flyhigh pro X wedge sacs
  • Nautiquehunter
    • Jun 2008
    • 2080
    I want to buy the wedge sacs for my 08 210 . I need to know what fittings to
    buy to hook up to the factory rear tanks. 90 degrees or straight quick connect or
    screw in ? I think I need 1" fittings. I doesn't look like a big job I want to have all the right fittings before I start . Any help would be appreciated.
  • Latonkaboarder
    • Jul 2007
    • 372
    • Mercer, Pennsylvania
    • 81 Ski Nautique when growing up 2007 SANTE 210 2008 SANTE 210
    RE: Help needed with Flyhigh pro X wedge sacs
    I would reccommend the fly high v drive sacs not the wedge sacs. The wedge sacs are for the earlier style 210 (03-06 I believe) that has wedge tanks. I used 90 degree fittings on mine that are a screw in type. I bought them at a local hardware store for about $2.00 a piece. I will probably change them out for the quick connect fittings so I can take the bags out easier. You will need 7 90 degree fittings and 1 T fitting if you are adding the integrated bow sac as well. If you are just installing the V drive sacs you will only need 4 90 degree fittings.
    Current: 08 Super Air 210 Team
    Previous: 07 Super Air 210 Team
    Previous: 02 MC Pro Star 197
    • Nautiquehunter
      • Jun 2008
      • 2080
      Thanks Latonkaboarder thats just what I needed.
